internet in linux netns is unreachable , nexthop is wrong
Здоров всем, я тут вопрос задал https://serverfault.com/questions/1087751/internet-in-linux-netns-is-unreachable-nexthop-is-wrong , но забугорные админы не могут помочь. Верю в наших. В чем ошибка? Почему netns с именем octo2 не выходить в Интернет? Все данные и детали - ниже: I have successfully setup 2 octoprints in 1 armbian linux on 2 different ports 5000 and 5001 by using netns. I can connect to them as 10.10.10.233:5000 and 10.10.10.233:5001 without any troubles. First of them (5000) is on the main system and has succesfull connection to Internet, second (5001 port) cant connect to internet, it can connect only to host via veth. All setup is: ``` sudo ip link add dev virt01 type veth peer name virt02 sudo ip netns add octo2 sudo ip link set virt01 netns octo2 sudo ip netns exec octo2 ip addr add 10.1.1.1/24 dev virt01 sudo ip addr add 10.1.1.2/24 dev virt02 sudo ip netns exec octo2 ip link set dev virt01 up sudo ip link set dev virt02 up sudo ip netns exec octo2 ip link set lo up sudo ip netns exec octo2 ip route add default via 10.1.1.2 #allow forward sudo ip netns exec octo2 sysctl net.ipv4.ip_forward=1 echo 1 > /proc/sys/net/ipv4/ip_forward ``` At this point in host have: netstat -rn Kernel IP routing table Destination Gateway Genmask Flags MSS Window irtt Iface 0.0.0.0 10.10.10.1 0.0.0.0 UG 0 0 0 eth0 10.1.1.0 0.0.0.0 255.255.255.0 U 0 0 0 virt02 10.10.10.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0 169.254.0.0 0.0.0.0 255.255.0.0 U 0 0 0 eth0 in netns: sudo ip netns exec octo2 netstat -rn Kernel IP routing table Destination Gateway Genmask Flags MSS Window irtt Iface 0.0.0.0 10.1.1.2 0.0.0.0 UG 0 0 0 virt01 10.1.1.0 0.0.0.0 255.255.255.0 U 0 0 0 virt01 So connections from host are GOOD to Internet (via router 10.10.10.1/24) and to netns orangepi:~$ ping 1.1.1.1 PING 1.1.1.1 (1.1.1.1) 56(84) bytes of data. 64 bytes from 1.1.1.1: icmp_seq=1 ttl=54 time=21.6 ms 64 bytes from 1.1.1.1: icmp_seq=2 ttl=54 time=21.4 ms orangepi:~$ ping 10.1.1.1 PING 10.1.1.1 (10.1.1.1) 56(84) bytes of data. 64 bytes from 10.1.1.1: icmp_seq=1 ttl=64 time=0.242 ms But from netns there is only connection to host and NO INTERNET: orangepi:~$ sudo ip netns exec octo2 ping 10.1.1.2 PING 10.1.1.2 (10.1.1.2) 56(84) bytes of data. 64 bytes from 10.1.1.2: icmp_seq=1 ttl=64 time=0.250 ms # ERROR HERE , NO INTERNET FROM NETNS: orangepi:~$ sudo ip netns exec octo2 ping 1.1.1.1 PING 1.1.1.1 (1.1.1.1) 56(84) bytes of data. ^C --- 1.1.1.1 ping statistics --- 2 packets transmitted, 0 received, 100% packet loss, time 1017ms orangepi:~$ sudo ip netns exec octo2 traceroute 1.1.1.1 traceroute to 1.1.1.1 (1.1.1.1), 30 hops max, 60 byte packets 1 _gateway (10.1.1.2) 0.288 ms 0.094 ms 0.079 ms 2 * * * 3 * * * 4 * * * 5 * * * 6 *^C host's iptables: orangepi:~$ sudo iptables -S -P INPUT ACCEPT -P FORWARD ACCEPT -P OUTPUT ACCEPT orangepi:~$ sudo iptables -S -t nat -P PREROUTING ACCEPT -P INPUT ACCEPT -P OUTPUT ACCEPT -P POSTROUTING ACCEPT Also some data: orangepi:~$ ip r default via 10.10.10.1 dev eth0 proto dhcp metric 100 10.1.1.0/24 dev virt02 proto kernel scope link src 10.1.1.2 10.10.10.0/24 dev eth0 proto kernel scope link src 10.10.10.234 metric 100 169.254.0.0/16 dev eth0 scope link metric 1000 orangepi:~$ sudo ip netns exec octo2 ip r default via 10.1.1.2 dev virt01 10.1.1.0/24 dev virt01 proto kernel scope link src 10.1.1.1 ed@orangepizero:~$ cat /proc/sys/net/ipv4/ip_forward 1 ed@orangepizero:~$ sudo ip netns exec octo2 cat /proc/sys/net/ipv4/ip_forward 1 orangepi:~$ sysctl net.ipv4.ip_forward net.ipv4.ip_forward = 1 orangepi:~$ sudo ip netns exec octo2 sysctl net.ipv4.ip_forward net.ipv4.ip_forward = 1 System have no ufw and other firewalls. How to fix and give netns access to Internet? ... |
| 27.12.2021, 16:33 |
А на хосте 10.10.10.1 есть маршрут к сети 10.1.1? Posted via ActualForum NNTP Server 1.5 ... |
| 27.12.2021, 16:57 |
Dimitry Sibiryakov, orangepi:~$ ip r 10.1.1.0/24 dev virt02 proto kernel scope link src 10.1.1.2 <<<<<<<<<< По идее, вот он. ... |
| 27.12.2021, 17:56 |
Я спрашивал про устройство с адресом 10.10.10.1, а не orangepi с адресом 10.10.10.233. Posted via ActualForum NNTP Server 1.5 ... |
| 27.12.2021, 18:07 |
Dimitry Sibiryakov, Увидел, хост 10.10.10.1 - роутер, он дает доступ наружу только для 10.10.10.0/24, это так, но он и не должен видеть попытку выхода наружу от 10.1.1.1, т.к. стоит default via 10.10.10.1 dev eth0 proto dhcp metric 100 - то есть пакеты из пая идут через eth0, а он имеет 10.10.10.0/24 dev eth0 proto kernel scope link src 10.10.10.234 то есть из 10.10.10.234. Так и должно быть. Что-то упущено с указанием \ форвардингом (?) маршрута 10.1.1.1 -> 10.10.10.234. Есть еще мысли? ... |
| 27.12.2021, 19:11 |
Шлюз (промежуточный) не меняет IP-адрес источника. Более того - он не имеет права этого делать. Следовательно роутер "видит" того, кому в тыртырнет низзя. Если требуется замаскировать источник - настраивайте NAT на промежуточном узле, чтобы "обмануть" ваш роутер. ... |
| 27.12.2021, 19:28 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1480898]: |
37ms |
40ms |
| others: | 249ms |
| total: | 377ms |
