Documents and Settings
Есть ли какая-нибудь переменная содержащая путь, например C:\Documents and Settings\Пользователь\ ... |
| 03.02.2006, 13:19:38 |
Код: plaintext 1. 2. ... |
| 03.02.2006, 14:02:18 |
Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. Нашёл в большой толстой книжке. Ещё один пример. Большое мерси ... |
| 03.02.2006, 14:46:12 |
Есть такая функция Environ(). Варианты: 1. Environ(i), i as Integer, Long 2. Environ(St), St as String Вот, что эта функция может выдать: "ALLUSERSPROFILE=C:\Documents and Settings\All Users" "APPDATA=C:\Documents and Settings\virus\Application Data" "CLASSPATH=C:\Program Files\Borland\InterBase\InterClient\interclient.jar" "CommonProgramFiles=C:\Program Files\Common Files" "COMPUTERNAME=LENA" "ComSpec=C:\WINNT\system32\cmd.exe" "HOMEDRIVE=C:" "HOMEPATH=\" "LOGONSERVER=\\LENA" "NUMBER_OF_PROCESSORS=1" "OS=Windows_NT" "Os2LibPath=C:\WINNT\system32\os2\dll;" "Path=C:\Program Files\Borland\Delphi7\Bin;C:\Program Files\Borland\Delphi7\Projects\Bpl\;C:\Program files\Inprise\vbroker\bin;C:\WINNT\system32;C:\WINNT;C:\WINNT\System32\Wbem;C:\PROGRA~1\Borland\Delphi6\Bin;C:\PROGRA~1\Borland\Delphi6\Projects\Bpl;C:\Program Files\Executive Software\Diskeeper\;C:\Program files\BC5\BIN;" "PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH" "PROCESSOR_ARCHITECTURE=x86" "PROCESSOR_IDENTIFIER=x86 Family 6 Model 8 Stepping 1, AuthenticAMD" "PROCESSOR_LEVEL=6" "PROCESSOR_REVISION=0801" "ProgramFiles=C:\Program Files" "SystemDrive=C:" "SystemRoot=C:\WINNT" "TEMP=C:\DOCUME~1\virus\LOCALS~1\Temp" "TMP=C:\DOCUME~1\virus\LOCALS~1\Temp" "USERDOMAIN=LENA" "USERNAME=virus" "USERPROFILE=C:\Documents and Settings\virus" "VBROKERDIR=C:\Program files\Inprise\vbroker" "windir=C:\WINNT" ... |
| 03.02.2006, 16:09:51 |
start [/forum/topic.php?desktop=1&fid=60&tid=2166448]: |
29ms |
26ms |
| others: | 187ms |
| total: | 273ms |
