multitable insert простой вопрос
если выполняются несколько условий одновременно будут сделаны все соотв. вставки ? у меня Код: plsql 1. 2. 3. 4. 5. 6. 7. 8. и null/not null может быть что угодно и как угодно ... |
| 07.09.2016, 14:24:29 |
grok, А доку покурить? ALL If you specify ALL, the default value, then the database evaluates each WHEN clause regardless of the results of the evaluation of any other WHEN clause. For each WHEN clause whose condition evaluates to true, the database executes the corresponding INTO clause list. FIRST If you specify FIRST, then the database evaluates each WHEN clause in the order in which it appears in the statement. For the first WHEN clause that evaluates to true, the database executes the corresponding INTO clause and skips subsequent WHEN clauses for the given row. SY. ... |
| 07.09.2016, 14:31:47 |
SYgrok, А доку покурить? ALL If you specify ALL, the default value, then the database evaluates each WHEN clause regardless of the results of the evaluation of any other WHEN clause. For each WHEN clause whose condition evaluates to true, the database executes the corresponding INTO clause list. FIRST If you specify FIRST, then the database evaluates each WHEN clause in the order in which it appears in the statement. For the first WHEN clause that evaluates to true, the database executes the corresponding INTO clause and skips subsequent WHEN clauses for the given row. SY. понял, спасибо ... |
| 07.09.2016, 15:42:43 |
start [/forum/topic.php?desktop=1&fid=52&tid=1887514]: |
68ms |
52ms |
| others: | 212ms |
| total: | 385ms |
