Ошибка при компиляции MYSQL
Пытаюсь сконфигурировать и установить мускул из исходников. OS Solaris 10 X86. Mysql 4.1.15 Хочу скомпилить сановским компилятором, а не gcc. Пишу авторCC="cc" CXX="CC" CFLAGS=" -xparallel -fast -xtarget=opteron -xarch=amd64" \ > LDFLAGS=" -xparallel -fast -xarch=amd64" \ > ./configure --prefix=/web/mysql \ > --localstatedir=/web/mysql/data \ > --with-unix-socket-path=/web/mysql/tmp/mysql.sock \ > --with-mysqld-user=mysql --with-extra-charsets=complex --enable-assembler \ > --with-charsets=cp1251 --with-berkeley-db=/usr/local/BerkeleyDB.4.2 \ > --with-berkeley-db-includes=/usr/local/BerkeleyDB.4.2/inclide \ > --with-berkeley-db-libs=/usr/local/BerkeleyDB.4.2/lib \ > --with-openssl=/usr/local/ssl --with-libwrap лезет ошибка configure: error: C compiler cannot create executables Вот что пишут на сайте мускула про аналогичную ошибку http://dev.mysql.com/doc/refman/4.0/ru/compilation-problems.html Если кто-нить сталкивался с этим не подскажете, как исправить? Вот что пишет конфиг в config.log This file contains any messages produced by compilers while running configure, to aid debugging if configure makes a mistake. It was created by configure, which was generated by GNU Autoconf 2.59. Invocation command line was $ ./configure --prefix=/web/mysql ## --------- ## ## Platform. ## ## --------- ## hostname = REX uname -m = i86pc uname -r = 5.10 uname -s = SunOS uname -v = Generic /usr/bin/uname -p = i386 /bin/uname -X = System = SunOS Node = REX Release = 5.10 KernelID = Generic Machine = i86pc BusType = <unknown> Serial = <unknown> Users = <unknown> OEM# = 0 Origin# = 1 NumCPU = 2 /bin/arch = i86pc /usr/bin/arch -k = i86pc /usr/convex/getsysinfo = unknown hostinfo = unknown /bin/machine = unknown /usr/bin/oslevel = unknown /bin/universe = unknown PATH: /usr/sfw/bin PATH: /usr/sbin PATH: /usr/bin PATH: /usr/dt/bin PATH: /usr/openwin/bin PATH: /usr/ccs/bin PATH: /usr/ucb PATH: /usr/local/bin PATH: /usr/local/sbin PATH: /opt/sfw/bin PATH: /opt/sfw/sbin PATH: /opt/SUNWspro/bin ## ----------- ## ## Core tests. ## ## ----------- ## configure:1676: checking build system type configure:1694: result: i386-pc-solaris2.10 configure:1702: checking host system type configure:1716: result: i386-pc-solaris2.10 configure:1724: checking target system type configure:1738: result: i386-pc-solaris2.10 configure:1768: checking for a BSD-compatible install configure:1823: result: /opt/sfw/bin/ginstall -c configure:1834: checking whether build environment is sane configure:1852: result: yes configure:1909: checking for gawk configure:1938: result: no configure:1909: checking for mawk configure:1938: result: no configure:1909: checking for nawk configure:1925: found /usr/bin/nawk configure:1935: result: nawk configure:1945: checking whether make sets $(MAKE) configure:1965: result: yes configure:2268: checking whether build environment is sane configure:2286: result: yes configure:2289: checking whether make sets $(MAKE) configure:2309: result: yes configure:2397: checking for gawk configure:2423: result: nawk configure:2479: checking for gcc configure:2505: result: cc configure:2749: checking for C compiler version configure:2752: cc --version </dev/null >&5 cc: Warning: option -- passed to ld usage: cc [ options] files. Use 'cc -flags' for details configure:2755: $? = 1 configure:2757: cc -v </dev/null >&5 usage: cc [ options] files. Use 'cc -flags' for details configure:2760: $? = 1 configure:2762: cc -V </dev/null >&5 cc: Sun C 5.7 2005/01/07 usage: cc [ options] files. Use 'cc -flags' for details configure:2765: $? = 1 configure:2788: checking for C compiler default output file name configure:2791: cc conftest.c >&5 configure:2794: $? = 0 configure:2840: result: a.out configure:2845: checking whether the C compiler works configure:2851: ./a.out configure:2854: $? = 0 configure:2871: result: yes configure:2878: checking whether we are cross compiling configure:2880: result: no configure:2883: checking for suffix of executables configure:2885: cc -o conftest conftest.c >&5 configure:2888: $? = 0 configure:2913: result: configure:2919: checking for suffix of object files configure:2940: cc -c conftest.c >&5 configure:2943: $? = 0 configure:2965: result: o configure:2969: checking whether we are using the GNU C compiler configure:2993: cc -c conftest.c >&5 "conftest.c", line 24: undefined symbol: choke "conftest.c", line 24: syntax error before or at: me cc: acomp failed for conftest.c configure:2999: $? = 2 configure: failed program was: | /* confdefs.h. */ | | #define PACKAGE_NAME "" | #define PACKAGE_TARNAME "" | #define PACKAGE_VERSION "" | #define PACKAGE_STRING "" | #define PACKAGE_BUGREPORT "" | #define PACKAGE "mysql" | #define VERSION "4.1.15" | #define PROTOCOL_VERSION 10 | #define DOT_FRM_VERSION 6 | #define NDB_VERSION_MAJOR 4 | #define NDB_VERSION_MINOR 1 | #define NDB_VERSION_BUILD 15 | #define NDB_VERSION_STATUS "" | #define SYSTEM_TYPE "pc-solaris2.10" | #define MACHINE_TYPE "i386" | /* end confdefs.h. */ | | int | main () | { | #ifndef __GNUC__ | choke me | #endif | | ; | return 0; | } configure:3025: result: no configure:3031: checking whether cc accepts -g configure:3052: cc -c -g conftest.c >&5 configure:3058: $? = 0 configure:3062: test -z || test ! -s conftest.err configure:3065: $? = 0 configure:3068: test -s conftest.o configure:3071: $? = 0 configure:3082: result: yes configure:3099: checking for cc option to accept ANSI C configure:3169: cc -c conftest.c >&5 "conftest.c", line 36: va_start: argument mismatch "conftest.c", line 62: warning: statement not reached configure:3175: $? = 0 configure:3179: test -z || test ! -s conftest.err configure:3182: $? = 0 configure:3185: test -s conftest.o configure:3188: $? = 0 configure:3206: result: none needed configure:3224: cc -c conftest.c >&5 "conftest.c", line 2: warning: old-style declaration or incorrect type for: choke "conftest.c", line 2: syntax error before or at: me "conftest.c", line 3: warning: old-style declaration or incorrect type for: me cc: acomp failed for conftest.c configure:3230: $? = 2 configure: failed program was: | #ifndef __cplusplus | choke me | #endif configure:3375: checking for style of include used by make configure:3403: result: GNU configure:3431: checking dependency style of cc configure:3516: result: none configure:3627: checking for C++ compiler version configure:3630: CC --version </dev/null >&5 CC: Warning: Option --version passed to ld, if ld is invoked, ignored otherwise /usr/ccs/bin/ld: illegal option -- version usage: ld [-6:abc:d:e:f:h:il:mo:p:rstu:z:B:CD:F:GI:L:M:N:P:Q:R:S:VY:?] file(s) [-64] enforce a 64-bit link-edit [-a] create an absolute file [-b] do not do special PIC relocations in a.out [-B direct] specify `direct' bindings for executable when run [-B dynamic | static] search for shared libraries|archives [-B eliminate] eliminate unqualified global symbols from the symbol table [-B group] relocate object from within group [-B local] reduce unqualified global symbols to local [-B reduce] process symbol reductions [-B symbolic] bind external references to definitions when creating shared objects [-c name] record configuration file `name' [-C] demangle C++ symbol name diagnostics [-d y | n] operate in dynamic|static mode [-D token,...] print diagnostic messages [-e epsym] use `epsym' as entry point address [-f name] specify library for which this file is an auxiliary filter [-F name] specify library for which this file is a filter [-G] create a shared object [-h name] use `name' as internal shared object identifier [-i] ignore LD_LIBRARY_PATH setting [-I name] use `name' as path of interpreter [-l x] search for libx.so or libx.a [-L path] search for libraries in directory `path' [-m] print memory map [-M mapfile] use processing directives contained in `mapfile' [-N string] create a dynamic dependency for `string' [-o outfile] name the output file `outfile' [-p auditlib] identify audit library to accompany this object [-P auditlib] identify audit library for processing the dependencies of this object [-Q y | n] do|do not place version information in output file [-r] create a relocatable object [-R path] specify a library search path to be used at run time [-s] strip any symbol and debugging information [-S supportlib] specify a link-edit support library [-t] do not warn of multiply-defined symbols that have different sizes or alignments [-u symname] create an undefined symbol `symname' [-V] print version information [-Y P,dirlist] use `dirlist' as a default path when searching for libraries [-z absexec] when building an executable absolute symbols referenced in dynamic objects are promoted to the executable [-z allextract | defaultextract | weakextract] extract all member files, only members that resolve undefined tor tentative symbols, or allow extraction of archive members to resolvetweak references from archive files [-z combreloc] combine multiple relocation sections [-z nocompstrtab] disable compression of string tables [-z defs] disallow undefined symbol references [-z direct | nodirect] enable|disable direct binding to shared object dependencies [-z endfiltee] marks a filtee such that it will terminate a filters search [-z finiarray=function] name of function to be appended to the .finiarray [-z groupperm | nogroupperm] enable|disable setting of group permissions on dynamic dependencies [-z ignore | record] ignore|record unused dynamic dependencies [-z initarray=function] name of function to be appended to the .initarray [-z initfirst] mark object to indicate that its .init section should be executed before the .init section of any other objects [-z interpose] dynamic object is to be an `interposer' on direct bindings [-z lazyload | nolazyload] enable|disable delayed loading of shared object dependencies [-z ld32=arg1,arg2,...] define arguments applicable to the 32-bit class of ld(1) [-z ld64=arg1,arg2,...] define arguments applicable to the 64-bit class of ld(1) [-z loadfltr] mark filter as requiring immediate loading of its filtees at runtime [-z muldefs] allow multiply-defined symbols [-z nodefs] allow undefined symbol references [-z nodefaultlib] mark object to ignore any default library search path [-z nodelete] mark object as non-deletable [-z nodlopen] mark object as non-dlopen()'able [-z nodump] mark object as non-dldump()'able [-z nopartial] expand any partially initialized symbols [-z noversion] don't record any version sections [-z now] mark object as requiring non-lazy binding [-z origin] mark object as requiring $ORIGIN processing [-z preinitarray=function] name of function to be appended to the .preinitarray [-z redlocsym] reduce local syms in .symtab to a minimum [-z rescan] rescan archive list until no further member extraction occurs [-z text] disallow output relocations against text [-z textoff] allow output relocations against text [-z textwarn] warn if there are relocations against text [-z verbose] generate warnings for suspicious processings configure:3633: $? = 1 configure:3635: CC -v </dev/null >&5 ### command line files and options (expanded): ### -v ### CC: Note: NLSPATH = /opt/SUNWspro/prod/bin/../lib/locale/%L/LC_MESSAGES/%N.cat:/opt/SUNWspro/prod/bin/../../lib/locale/%L/LC_MESSAGES/%N.cat configure:3638: $? = 0 configure:3640: CC -V </dev/null >&5 CC: Sun C++ 5.7 2005/01/07 configure:3643: $? = 0 configure:3646: checking whether we are using the GNU C++ compiler configure:3670: CC -c conftest.cc >&5 "conftest.cc", line 24: Error: choke is not defined. 1 Error(s) detected. configure:3676: $? = 1 configure: failed program was: | /* confdefs.h. */ | | #define PACKAGE_NAME "" | #define PACKAGE_TARNAME "" | #define PACKAGE_VERSION "" | #define PACKAGE_STRING "" | #define PACKAGE_BUGREPORT "" | #define PACKAGE "mysql" | #define VERSION "4.1.15" | #define PROTOCOL_VERSION 10 | #define DOT_FRM_VERSION 6 | #define NDB_VERSION_MAJOR 4 | #define NDB_VERSION_MINOR 1 | #define NDB_VERSION_BUILD 15 | #define NDB_VERSION_STATUS "" | #define SYSTEM_TYPE "pc-solaris2.10" | #define MACHINE_TYPE "i386" | /* end confdefs.h. */ | | int | main () | { | #ifndef __GNUC__ | choke me | #endif | | ; | return 0; | } configure:3702: result: no configure:3708: checking whether CC accepts -g configure:3729: CC -c -g conftest.cc >&5 configure:3735: $? = 0 configure:3739: test -z || test ! -s conftest.err configure:3742: $? = 0 configure:3745: test -s conftest.o configure:3748: $? = 0 configure:3759: result: yes configure:3802: CC -c conftest.cc >&5 configure:3808: $? = 0 configure:3812: test -z || test ! -s conftest.err configure:3815: $? = 0 configure:3818: test -s conftest.o configure:3821: $? = 0 configure:3847: CC -c conftest.cc >&5 "conftest.cc", line 23: Error: The function "exit" must have a prototype. 1 Error(s) detected. configure:3853: $? = 1 configure: failed program was: | /* confdefs.h. */ | | #define PACKAGE_NAME "" | #define PACKAGE_TARNAME "" | #define PACKAGE_VERSION "" | #define PACKAGE_STRING "" | #define PACKAGE_BUGREPORT "" | #define PACKAGE "mysql" | #define VERSION "4.1.15" | #define PROTOCOL_VERSION 10 | #define DOT_FRM_VERSION 6 | #define NDB_VERSION_MAJOR 4 | #define NDB_VERSION_MINOR 1 | #define NDB_VERSION_BUILD 15 | #define NDB_VERSION_STATUS "" | #define SYSTEM_TYPE "pc-solaris2.10" | #define MACHINE_TYPE "i386" | /* end confdefs.h. */ | | int | main () | { | exit (42); | ; | return 0; | } configure:3802: CC -c conftest.cc >&5 "conftest.cc", line 19: Error: The class member exit(int) cannot be declared outside the class. "conftest.cc", line 19: Error: exit is not a member of std. 2 Error(s) detected. configure:3808: $? = 2 configure: failed program was: | /* confdefs.h. */ | | #define PACKAGE_NAME "" | #define PACKAGE_TARNAME "" | #define PACKAGE_VERSION "" | #define PACKAGE_STRING "" | #define PACKAGE_BUGREPORT "" | #define PACKAGE "mysql" | #define VERSION "4.1.15" | #define PROTOCOL_VERSION 10 | #define DOT_FRM_VERSION 6 | #define NDB_VERSION_MAJOR 4 | #define NDB_VERSION_MINOR 1 | #define NDB_VERSION_BUILD 15 | #define NDB_VERSION_STATUS "" | #define SYSTEM_TYPE "pc-solaris2.10" | #define MACHINE_TYPE "i386" | /* end confdefs.h. */ | extern "C" void std::exit (int) throw (); using std::exit; | #include <stdlib.h> | int | main () | { | exit (42); | ; | return 0; | } configure:3802: CC -c conftest.cc >&5 "conftest.cc", line 19: Error: The class member exit(int) cannot be declared outside the class. "conftest.cc", line 19: Error: exit is not a member of std. 2 Error(s) detected. configure:3808: $? = 2 configure: failed program was: | /* confdefs.h. */ | | #define PACKAGE_NAME "" | #define PACKAGE_TARNAME "" | #define PACKAGE_VERSION "" | #define PACKAGE_STRING "" | #define PACKAGE_BUGREPORT "" | #define PACKAGE "mysql" | #define VERSION "4.1.15" | #define PROTOCOL_VERSION 10 | #define DOT_FRM_VERSION 6 | #define NDB_VERSION_MAJOR 4 | #define NDB_VERSION_MINOR 1 | #define NDB_VERSION_BUILD 15 | #define NDB_VERSION_STATUS "" | #define SYSTEM_TYPE "pc-solaris2.10" | #define MACHINE_TYPE "i386" | /* end confdefs.h. */ | extern "C" void std::exit (int); using std::exit; | #include <stdlib.h> | int | main () | { | exit (42); | ; | return 0; | } configure:3802: CC -c conftest.cc >&5 "/usr/include/iso/stdlib_iso.h", line 124: Error: The prior declaration for std::exit(int) has an exception specification. 1 Error(s) detected. configure:3808: $? = 1 configure: failed program was: | /* confdefs.h. */ | | #define PACKAGE_NAME "" | #define PACKAGE_TARNAME "" | #define PACKAGE_VERSION "" | #define PACKAGE_STRING "" | #define PACKAGE_BUGREPORT "" | #define PACKAGE "mysql" | #define VERSION "4.1.15" | #define PROTOCOL_VERSION 10 | #define DOT_FRM_VERSION 6 | #define NDB_VERSION_MAJOR 4 | #define NDB_VERSION_MINOR 1 | #define NDB_VERSION_BUILD 15 | #define NDB_VERSION_STATUS "" | #define SYSTEM_TYPE "pc-solaris2.10" | #define MACHINE_TYPE "i386" | /* end confdefs.h. */ | extern "C" void exit (int) throw (); | #include <stdlib.h> | int | main () | { | exit (42); | ; | return 0; | } configure:3802: CC -c conftest.cc >&5 configure:3808: $? = 0 configure:3812: test -z || test ! -s conftest.err configure:3815: $? = 0 configure:3818: test -s conftest.o configure:3821: $? = 0 configure:3847: CC -c conftest.cc >&5 configure:3853: $? = 0 configure:3857: test -z || test ! -s conftest.err configure:3860: $? = 0 configure:3863: test -s conftest.o configure:3866: $? = 0 configure:3891: checking dependency style of CC configure:3976: result: none configure:3998: checking how to run the C preprocessor configure:4033: cc -E conftest.c configure:4039: $? = 0 configure:4071: cc -E conftest.c "conftest.c", line 22: Can't find include file ac_nonexistent.h cc: preprocessor failed for conftest.c configure:4077: $? = 2 configure: failed program was: | /* confdefs.h. */ | | #define PACKAGE_NAME "" | #define PACKAGE_TARNAME "" | #define PACKAGE_VERSION "" | #define PACKAGE_STRING "" | #define PACKAGE_BUGREPORT "" | #define PACKAGE "mysql" | #define VERSION "4.1.15" | #define PROTOCOL_VERSION 10 | #define DOT_FRM_VERSION 6 | #define NDB_VERSION_MAJOR 4 | #define NDB_VERSION_MINOR 1 | #define NDB_VERSION_BUILD 15 | #define NDB_VERSION_STATUS "" | #define SYSTEM_TYPE "pc-solaris2.10" | #define MACHINE_TYPE "i386" | #ifdef __cplusplus | extern "C" void exit (int); | #endif | /* end confdefs.h. */ | #include <ac_nonexistent.h> configure:4116: result: cc -E configure:4140: cc -E conftest.c configure:4146: $? = 0 configure:4178: cc -E conftest.c "conftest.c", line 22: Can't find include file ac_nonexistent.h cc: preprocessor failed for conftest.c configure:4184: $? = 2 configure: failed program was: | /* confdefs.h. */ | | #define PACKAGE_NAME "" | #define PACKAGE_TARNAME "" | #define PACKAGE_VERSION "" | #define PACKAGE_STRING "" | #define PACKAGE_BUGREPORT "" | #define PACKAGE "mysql" | #define VERSION "4.1.15" | #define PROTOCOL_VERSION 10 | #define DOT_FRM_VERSION 6 | #define NDB_VERSION_MAJOR 4 | #define NDB_VERSION_MINOR 1 | #define NDB_VERSION_BUILD 15 | #define NDB_VERSION_STATUS "" | #define SYSTEM_TYPE "pc-solaris2.10" | #define MACHINE_TYPE "i386" | #ifdef __cplusplus | extern "C" void exit (int); | #endif | /* end confdefs.h. */ | #include <ac_nonexistent.h> configure:4239: checking "C Compiler version" configure:4241: result: "cc " configure:4256: checking "C++ compiler version" configure:4258: result: "CC " configure:4283: checking for as configure:4301: found /usr/ccs/bin/as configure:4314: result: /usr/ccs/bin/as configure:4364: checking for ranlib configure:4380: found /usr/ccs/bin/ranlib configure:4391: result: ranlib configure:4477: checking for a sed that does not truncate output configure:4531: result: /usr/bin/sed configure:4534: checking for egrep configure:4544: result: egrep configure:4593: checking for non-GNU ld configure:4627: result: /usr/ccs/bin/ld configure:4636: checking if the linker (/usr/ccs/bin/ld) is GNU ld configure:4651: result: no configure:4656: checking for /usr/ccs/bin/ld option to reload object files configure:4663: result: -r configure:4672: checking for BSD-compatible nm configure:4714: result: /usr/ccs/bin/nm -p configure:4718: checking whether ln -s works configure:4722: result: yes configure:4729: checking how to recognise dependent libraries configure:4912: result: pass_all configure:5122: checking for ANSI C header files configure:5147: cc -c conftest.c >&5 configure:5153: $? = 0 configure:5157: test -z || test ! -s conftest.err configure:5160: $? = 0 configure:5163: test -s conftest.o configure:5166: $? = 0 configure:5255: cc -o conftest conftest.c >&5 configure:5258: $? = 0 configure:5260: ./conftest configure:5263: $? = 0 configure:5278: result: yes configure:5302: checking for sys/types.h configure:5318: cc -c conftest.c >&5 configure:5324: $? = 0 configure:5328: test -z || test ! -s conftest.err configure:5331: $? = 0 configure:5334: test -s conftest.o configure:5337: $? = 0 configure:5348: result: yes configure:5302: checking for sys/stat.h configure:5318: cc -c conftest.c >&5 configure:5324: $? = 0 configure:5328: test -z || test ! -s conftest.err configure:5331: $? = 0 configure:5334: test -s conftest.o configure:5337: $? = 0 configure:5348: result: yes configure:5302: checking for stdlib.h configure:5318: cc -c conftest.c >&5 configure:5324: $? = 0 configure:5328: test -z || test ! -s conftest.err configure:5331: $? = 0 configure:5334: test -s conftest.o configure:5337: $? = 0 configure:5348: result: yes configure:5302: checking for string.h configure:5318: cc -c conftest.c >&5 configure:5324: $? = 0 configure:5328: test -z || test ! -s conftest.err configure:5331: $? = 0 configure:5334: test -s conftest.o configure:5337: $? = 0 configure:5348: result: yes configure:5302: checking for memory.h configure:5318: cc -c conftest.c >&5 configure:5324: $? = 0 configure:5328: test -z || test ! -s conftest.err configure:5331: $? = 0 configure:5334: test -s conftest.o configure:5337: $? = 0 configure:5348: result: yes configure:5302: checking for strings.h configure:5318: cc -c conftest.c >&5 configure:5324: $? = 0 configure:5328: test -z || test ! -s conftest.err configure:5331: $? = 0 configure:5334: test -s conftest.o configure:5337: $? = 0 configure:5348: result: yes configure:5302: checking for inttypes.h configure:5318: cc -c conftest.c >&5 configure:5324: $? = 0 configure:5328: test -z || test ! -s conftest.err configure:5331: $? = 0 configure:5334: test -s conftest.o configure:5337: $? = 0 configure:5348: result: yes configure:5302: checking for stdint.h configure:5318: cc -c conftest.c >&5 configure:5324: $? = 0 configure:5328: test -z || test ! -s conftest.err configure:5331: $? = 0 configure:5334: test -s conftest.o configure:5337: $? = 0 configure:5348: result: yes configure:5302: checking for unistd.h configure:5318: cc -c conftest.c >&5 configure:5324: $? = 0 configure:5328: test -z || test ! -s conftest.err configure:5331: $? = 0 configure:5334: test -s conftest.o configure:5337: $? = 0 configure:5348: result: yes configure:5374: checking dlfcn.h usability configure:5386: cc -c conftest.c >&5 configure:5392: $? = 0 configure:5396: test -z || test ! -s conftest.err configure:5399: $? = 0 configure:5402: test -s conftest.o configure:5405: $? = 0 configure:5415: result: yes configure:5419: checking dlfcn.h presence configure:5429: cc -E conftest.c configure:5435: $? = 0 configure:5455: result: yes configure:5490: checking for dlfcn.h configure:5497: result: yes configure:5515: checking how to run the C++ preprocessor configure:5546: CC -E conftest.cc configure:5552: $? = 0 configure:5584: CC -E conftest.cc "conftest.cc", line 33: Error: Could not open include file<ac_nonexistent.h>. 1 Error(s) detected. configure:5590: $? = 1 configure: failed program was: | /* confdefs.h. */ | | #define PACKAGE_NAME "" | #define PACKAGE_TARNAME "" | #define PACKAGE_VERSION "" | #define PACKAGE_STRING "" | #define PACKAGE_BUGREPORT "" | #define PACKAGE "mysql" | #define VERSION "4.1.15" | #define PROTOCOL_VERSION 10 | #define DOT_FRM_VERSION 6 | #define NDB_VERSION_MAJOR 4 | #define NDB_VERSION_MINOR 1 | #define NDB_VERSION_BUILD 15 | #define NDB_VERSION_STATUS "" | #define SYSTEM_TYPE "pc-solaris2.10" | #define MACHINE_TYPE "i386" | #ifdef __cplusplus | extern "C" void exit (int); | #endif | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | /* end confdefs.h. */ | #include <ac_nonexistent.h> configure:5629: result: CC -E configure:5653: CC -E conftest.cc configure:5659: $? = 0 configure:5691: CC -E conftest.cc "conftest.cc", line 33: Error: Could not open include file<ac_nonexistent.h>. 1 Error(s) detected. configure:5697: $? = 1 configure: failed program was: | /* confdefs.h. */ | | #define PACKAGE_NAME "" | #define PACKAGE_TARNAME "" | #define PACKAGE_VERSION "" | #define PACKAGE_STRING "" | #define PACKAGE_BUGREPORT "" | #define PACKAGE "mysql" | #define VERSION "4.1.15" | #define PROTOCOL_VERSION 10 | #define DOT_FRM_VERSION 6 | #define NDB_VERSION_MAJOR 4 | #define NDB_VERSION_MINOR 1 | #define NDB_VERSION_BUILD 15 | #define NDB_VERSION_STATUS "" | #define SYSTEM_TYPE "pc-solaris2.10" | #define MACHINE_TYPE "i386" | #ifdef __cplusplus | extern "C" void exit (int); | #endif | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | /* end confdefs.h. */ | #include <ac_nonexistent.h> configure:5792: checking for g77 configure:5808: found /opt/sfw/bin/g77 configure:5818: result: g77 configure:5833: checking for Fortran 77 compiler version configure:5836: g77 --version </dev/null >&5 GNU Fortran (GCC) 3.4.2 Copyright (C) 2004 Free Software Foundation, Inc. GNU Fortran comes with NO WARRANTY, to the extent permitted by law. You may redistribute copies of GNU Fortran under the terms of the GNU General Public License. For more information about these matters, see the file named COPYING or type the command `info -f g77 Copying'. configure:5839: $? = 0 configure:5841: g77 -v </dev/null >&5 Reading specs from /opt/sfw/lib/gcc/i386-pc-solaris2.10/3.4.2/specs Configured with: ../gcc-3.4.2/configure --prefix=/opt/sfw --with-ld=/usr/ccs/bin/ld --with-gnu-as --with-as=/opt/sfw/bin/gas --enable-shared --disable-libgcj Thread model: posix gcc version 3.4.2 configure:5844: $? = 0 configure:5846: g77 -V </dev/null >&5 g77: `-V' option must have argument configure:5849: $? = 1 configure:5857: checking whether we are using the GNU Fortran 77 compiler configure:5871: g77 -c conftest.F >&5 configure:5877: $? = 0 configure:5881: test -z || test ! -s conftest.err configure:5884: $? = 0 configure:5887: test -s conftest.o configure:5890: $? = 0 configure:5903: result: yes configure:5909: checking whether g77 accepts -g configure:5921: g77 -c -g conftest.f >&5 configure:5927: $? = 0 configure:5931: test -z || test ! -s conftest.err configure:5934: $? = 0 configure:5937: test -s conftest.o configure:5940: $? = 0 configure:5952: result: yes configure:5982: checking the maximum length of command line arguments configure:6047: result: 262144 configure:6058: checking command to parse /usr/ccs/bin/nm -p output from cc object configure:6147: cc -c conftest.c >&5 configure:6150: $? = 0 configure:6154: /usr/ccs/bin/nm -p conftest.o \| sed -n -e 's/^.*[ ]\([BDRT][BDRT]*\)[ ][ ]*\(\)\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2\3 \3/p' \> conftest.nm configure:6157: $? = 0 configure:6209: cc -o conftest conftest.c conftstm.o >&5 configure:6212: $? = 0 configure:6250: result: ok configure:6254: checking for objdir configure:6269: result: .libs configure:6359: checking for ar configure:6375: found /usr/ccs/bin/ar configure:6386: result: ar configure:6439: checking for ranlib configure:6466: result: ranlib configure:6519: checking for strip configure:6535: found /usr/ccs/bin/strip configure:6546: result: strip configure:6808: checking if cc static flag works configure:6831: result: yes configure:6897: checking for cc option to produce PIC configure:7074: result: -KPIC configure:7082: checking if cc PIC flag -KPIC works configure:7100: cc -c -KPIC -DPIC conftest.c >&5 configure:7104: $? = 0 configure:7115: result: yes configure:7139: checking if cc supports -c -o file.o configure:7160: cc -c -o out/conftest2.o conftest.c >&5 configure:7164: $? = 0 configure:7184: result: yes configure:7210: checking whether the cc linker (/usr/ccs/bin/ld) supports shared libraries configure:8058: result: yes configure:8129: checking dynamic linker characteristics configure:8690: result: solaris2.10 ld.so configure:8694: checking how to hardcode library paths into programs configure:8719: result: immediate configure:8733: checking whether stripping libraries is possible configure:8754: result: no configure:9568: checking if libtool supports shared libraries configure:9570: result: yes configure:9573: checking whether to build shared libraries configure:9631: result: yes configure:9634: checking whether to build static libraries configure:9638: result: yes configure:9730: creating libtool configure:10419: checking whether the CC linker (/usr/ccs/bin/ld) supports shared libraries configure:11247: result: yes configure:11265: CC -c conftest.cc >&5 configure:11268: $? = 0 configure:11364: checking for CC option to produce PIC configure:11616: result: -KPIC configure:11624: checking if CC PIC flag -KPIC works configure:11642: CC -c -KPIC -DPIC conftest.cc >&5 configure:11646: $? = 0 configure:11657: result: yes configure:11681: checking if CC supports -c -o file.o configure:11702: CC -c -o out/conftest2.o conftest.cc >&5 configure:11706: $? = 0 configure:11726: result: yes configure:11752: checking whether the CC linker (/usr/ccs/bin/ld) supports shared libraries configure:11777: result: yes configure:11848: checking dynamic linker characteristics configure:12409: result: solaris2.10 ld.so configure:12413: checking how to hardcode library paths into programs configure:12438: result: immediate configure:12452: checking whether stripping libraries is possible configure:12473: result: no configure:13764: checking if libtool supports shared libraries configure:13766: result: yes configure:13769: checking whether to build shared libraries configure:13787: result: yes configure:13790: checking whether to build static libraries configure:13794: result: yes configure:13806: checking for g77 option to produce PIC configure:13983: result: -KPIC configure:13991: checking if g77 PIC flag -KPIC works configure:14009: g77 -c -g -O2 -KPIC conftest.f >&5 g77: unrecognized option `-KPIC' configure:14013: $? = 0 configure:14024: result: no configure:14048: checking if g77 supports -c -o file.o configure:14069: g77 -c -g -O2 -o out/conftest2.o conftest.f >&5 configure:14073: $? = 0 configure:14093: result: yes configure:14119: checking whether the g77 linker (/usr/ccs/bin/ld) supports shared libraries configure:14947: result: yes configure:15018: checking dynamic linker characteristics configure:15579: result: solaris2.10 ld.so configure:15583: checking how to hardcode library paths into programs configure:15608: result: immediate configure:15622: checking whether stripping libraries is possible configure:15643: result: no configure:19755: checking for a BSD-compatible install configure:19810: result: /opt/sfw/bin/ginstall -c configure:19828: checking for bison configure:19844: found /usr/sfw/bin/bison configure:19854: result: bison -y configure:19867: checking for pdftex configure:19896: result: no configure:19902: checking for tex configure:19931: result: no configure:19936: checking "return type of sprintf" configure:19975: cc -o conftest conftest.c >&5 configure:19978: $? = 0 configure:19980: ./conftest configure:19983: $? = 255 configure: program exited with status 255 configure: failed program was: | /* confdefs.h. */ | | #define PACKAGE_NAME "" | #define PACKAGE_TARNAME "" | #define PACKAGE_VERSION "" | #define PACKAGE_STRING "" | #define PACKAGE_BUGREPORT "" | #define PACKAGE "mysql" | #define VERSION "4.1.15" | #define PROTOCOL_VERSION 10 | #define DOT_FRM_VERSION 6 | #define NDB_VERSION_MAJOR 4 | #define NDB_VERSION_MINOR 1 | #define NDB_VERSION_BUILD 15 | #define NDB_VERSION_STATUS "" | #define SYSTEM_TYPE "pc-solaris2.10" | #define MACHINE_TYPE "i386" | #ifdef __cplusplus | extern "C" void exit (int); | #endif | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | /* end confdefs.h. */ | | int main() | { | char* s = "hello"; | char buf[6]; | if((int)sprintf(buf, s) == strlen(s)) | return 0; | | return -1; | } | configure:20022: cc -o conftest conftest.c >&5 configure:20025: $? = 0 configure:20027: ./conftest configure:20030: $? = 255 configure: program exited with status 255 configure: failed program was: | /* confdefs.h. */ | | #define PACKAGE_NAME "" | #define PACKAGE_TARNAME "" | #define PACKAGE_VERSION "" | #define PACKAGE_STRING "" | #define PACKAGE_BUGREPORT "" | #define PACKAGE "mysql" | #define VERSION "4.1.15" | #define PROTOCOL_VERSION 10 | #define DOT_FRM_VERSION 6 | #define NDB_VERSION_MAJOR 4 | #define NDB_VERSION_MINOR 1 | #define NDB_VERSION_BUILD 15 | #define NDB_VERSION_STATUS "" | #define SYSTEM_TYPE "pc-solaris2.10" | #define MACHINE_TYPE "i386" | #ifdef __cplusplus | extern "C" void exit (int); | #endif | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | /* end confdefs.h. */ | | int main() | { | char* s = "hello"; | char buf[6]; | if((char*)sprintf(buf,s) == buf + strlen(s)) | return 0; | return -1; | } configure:20050: result: "garbage" configure:20076: checking for uname configure:20094: found /usr/bin/uname configure:20107: result: /usr/bin/uname configure:20117: checking operating system configure:20131: result: SunOS configure:20335: checking "if we should use 'skip-locking' as default for solaris2.10" configure:20352: result: "no" configure:20360: checking for ln configure:20378: found /usr/bin/ln configure:20391: result: /usr/bin/ln configure:20401: checking for ln configure:20419: found /usr/bin/ln configure:20432: result: /usr/bin/ln configure:20448: checking for mv configure:20466: found /usr/bin/mv configure:20479: result: /usr/bin/mv configure:20488: checking for rm configure:20506: found /usr/bin/rm configure:20519: result: /usr/bin/rm configure:20528: checking for cp configure:20546: found /usr/bin/cp configure:20559: result: /usr/bin/cp configure:20568: checking for sed configure:20599: result: /usr/bin/sed configure:20608: checking for cmp configure:20626: found /usr/bin/cmp configure:20639: result: /usr/bin/cmp configure:20648: checking for chmod configure:20666: found /usr/bin/chmod configure:20679: result: /usr/bin/chmod configure:20688: checking for hostname configure:20706: found /usr/bin/hostname configure:20719: result: /usr/bin/hostname configure:20732: checking for gnutar configure:20761: result: no configure:20732: checking for gtar configure:20748: found /usr/sfw/bin/gtar configure:20758: result: gtar configure:20771: checking for perl configure:20789: found /usr/bin/perl configure:20802: result: /usr/bin/perl configure:20868: checking for doxygen configure:20899: result: no configure:20908: checking for pdflatex configure:20939: result: no configure:20948: checking for makeindex configure:20979: result: no configure:20993: checking for ps configure:21011: found /usr/bin/ps configure:21024: result: /usr/bin/ps configure:21031: checking "how to check if pid exists" configure:21075: result: "/usr/bin/ps -p $$PID | grep -v grep | grep mysqld > /dev/null" configure:21081: checking for kill configure:21099: found /usr/bin/kill configure:21112: result: /usr/bin/kill configure:21119: checking "for kill switches" configure:21133: result: "/usr/bin/kill -0 $$PID > /dev/null 2> /dev/null" configure:21138: checking for cc option to accept ANSI C configure:21182: cc -c conftest.c >&5 "conftest.c", line 35: warning: old-style declaration or incorrect type for: choke "conftest.c", line 35: syntax error before or at: me "conftest.c", line 43: warning: old-style declaration or incorrect type for: me cc: acomp failed for conftest.c configure:21188: $? = 2 configure: failed program was: | /* confdefs.h. */ | | #define PACKAGE_NAME "" | #define PACKAGE_TARNAME "" | #define PACKAGE_VERSION "" | #define PACKAGE_STRING "" | #define PACKAGE_BUGREPORT "" | #define PACKAGE "mysql" | #define VERSION "4.1.15" | #define PROTOCOL_VERSION 10 | #define DOT_FRM_VERSION 6 | #define NDB_VERSION_MAJOR 4 | #define NDB_VERSION_MINOR 1 | #define NDB_VERSION_BUILD 15 | #define NDB_VERSION_STATUS "" | #define SYSTEM_TYPE "pc-solaris2.10" | #define MACHINE_TYPE "i386" | #ifdef __cplusplus | extern "C" void exit (int); | #endif | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define SPRINTF_RETURNS_GARBAGE 1 | /* end confdefs.h. */ | #if !defined(__STDC__) | choke me | #endif | /* DYNIX/ptx V4.1.3 can't compile sys/stat.h with -Xc -D__EXTENSIONS__. */ | #ifdef _SEQUENT_ | # include <sys/types.h> | # include <sys/stat.h> | #endif | | int | main () | { | | int test (int i, double x); | struct s1 {int (*f) (int a);}; | struct s2 {int (*f) (double a);}; | ; | return 0; | } configure:21182: cc -qlanglvl=ansi -c conftest.c >&5 cc: illegal option -qlanglvl=ansi configure:21188: $? = 1 configure: failed program was: | /* confdefs.h. */ | | #define PACKAGE_NAME "" | #define PACKAGE_TARNAME "" | #define PACKAGE_VERSION "" | #define PACKAGE_STRING "" | #define PACKAGE_BUGREPORT "" | #define PACKAGE "mysql" | #define VERSION "4.1.15" | #define PROTOCOL_VERSION 10 | #define DOT_FRM_VERSION 6 | #define NDB_VERSION_MAJOR 4 | #define NDB_VERSION_MINOR 1 | #define NDB_VERSION_BUILD 15 | #define NDB_VERSION_STATUS "" | #define SYSTEM_TYPE "pc-solaris2.10" | #define MACHINE_TYPE "i386" | #ifdef __cplusplus | extern "C" void exit (int); | #endif | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define SPRINTF_RETURNS_GARBAGE 1 | /* end confdefs.h. */ | #if !defined(__STDC__) | choke me | #endif | /* DYNIX/ptx V4.1.3 can't compile sys/stat.h with -Xc -D__EXTENSIONS__. */ | #ifdef _SEQUENT_ | # include <sys/types.h> | # include <sys/stat.h> | #endif | | int | main () | { | | int test (int i, double x); | struct s1 {int (*f) (int a);}; | struct s2 {int (*f) (double a);}; | ; | return 0; | } configure:21182: cc -std1 -c conftest.c >&5 cc: Warning: illegal option -d1 "conftest.c", line 35: warning: old-style declaration or incorrect type for: choke "conftest.c", line 35: syntax error before or at: me "conftest.c", line 43: warning: old-style declaration or incorrect type for: me cc: acomp failed for conftest.c configure:21188: $? = 2 configure: failed program was: | /* confdefs.h. */ | | #define PACKAGE_NAME "" | #define PACKAGE_TARNAME "" | #define PACKAGE_VERSION "" | #define PACKAGE_STRING "" | #define PACKAGE_BUGREPORT "" | #define PACKAGE "mysql" | #define VERSION "4.1.15" | #define PROTOCOL_VERSION 10 | #define DOT_FRM_VERSION 6 | #define NDB_VERSION_MAJOR 4 | #define NDB_VERSION_MINOR 1 | #define NDB_VERSION_BUILD 15 | #define NDB_VERSION_STATUS "" | #define SYSTEM_TYPE "pc-solaris2.10" | #define MACHINE_TYPE "i386" | #ifdef __cplusplus | extern "C" void exit (int); | #endif | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define SPRINTF_RETURNS_GARBAGE 1 | /* end confdefs.h. */ | #if !defined(__STDC__) | choke me | #endif | /* DYNIX/ptx V4.1.3 can't compile sys/stat.h with -Xc -D__EXTENSIONS__. */ | #ifdef _SEQUENT_ | # include <sys/types.h> | # include <sys/stat.h> | #endif | | int | main () | { | | int test (int i, double x); | struct s1 {int (*f) (int a);}; | struct s2 {int (*f) (double a);}; | ; | return 0; | } configure:21182: cc -Aa -D_HPUX_SOURCE -c conftest.c >&5 unknown flag -Aa "conftest.c", line 35: warning: old-style declaration or incorrect type for: choke "conftest.c", line 35: syntax error before or at: me "conftest.c", line 43: warning: old-style declaration or incorrect type for: me cc: acomp failed for conftest.c configure:21188: $? = 2 configure: failed program was: | /* confdefs.h. */ | | #define PACKAGE_NAME "" | #define PACKAGE_TARNAME "" | #define PACKAGE_VERSION "" | #define PACKAGE_STRING "" | #define PACKAGE_BUGREPORT "" | #define PACKAGE "mysql" | #define VERSION "4.1.15" | #define PROTOCOL_VERSION 10 | #define DOT_FRM_VERSION 6 | #define NDB_VERSION_MAJOR 4 | #define NDB_VERSION_MINOR 1 | #define NDB_VERSION_BUILD 15 | #define NDB_VERSION_STATUS "" | #define SYSTEM_TYPE "pc-solaris2.10" | #define MACHINE_TYPE "i386" | #ifdef __cplusplus | extern "C" void exit (int); | #endif | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define SPRINTF_RETURNS_GARBAGE 1 | /* end confdefs.h. */ | #if !defined(__STDC__) | choke me | #endif | /* DYNIX/ptx V4.1.3 can't compile sys/stat.h with -Xc -D__EXTENSIONS__. */ | #ifdef _SEQUENT_ | # include <sys/types.h> | # include <sys/stat.h> | #endif | | int | main () | { | | int test (int i, double x); | struct s1 {int (*f) (int a);}; | struct s2 {int (*f) (double a);}; | ; | return 0; | } configure:21215: result: no configure:21234: error: MySQL requires an ANSI C compiler (and a C++ compiler). Try gcc. See the Installation chapter in the Reference Manual. ## ---------------- ## ## Cache variables. ## ## ---------------- ## ac_cv_build=i386-pc-solaris2.10 ac_cv_build_alias=i386-pc-solaris2.10 ac_cv_c_compiler_gnu=no ac_cv_cxx_compiler_gnu=no ac_cv_env_CCASFLAGS_set= ac_cv_env_CCASFLAGS_value= ac_cv_env_CCAS_set= ac_cv_env_CCAS_value= ac_cv_env_CC_set=set ac_cv_env_CC_value=cc ac_cv_env_CFLAGS_set= ac_cv_env_CFLAGS_value= ac_cv_env_CPPFLAGS_set= ac_cv_env_CPPFLAGS_value= ac_cv_env_CPP_set= ac_cv_env_CPP_value= ac_cv_env_CXXCPP_set= ac_cv_env_CXXCPP_value= ac_cv_env_CXXFLAGS_set= ac_cv_env_CXXFLAGS_value= ac_cv_env_CXX_set=set ac_cv_env_CXX_value=CC ac_cv_env_F77_set= ac_cv_env_F77_value= ac_cv_env_FFLAGS_set= ac_cv_env_FFLAGS_value= ac_cv_env_LDFLAGS_set= ac_cv_env_LDFLAGS_value= ac_cv_env_build_alias_set= ac_cv_env_build_alias_value= ac_cv_env_host_alias_set= ac_cv_env_host_alias_value= ac_cv_env_target_alias_set= ac_cv_env_target_alias_value= ac_cv_exeext= ac_cv_f77_compiler_gnu=yes ac_cv_header_dlfcn_h=yes ac_cv_header_inttypes_h=yes ac_cv_header_memory_h=yes ac_cv_header_stdc=yes ac_cv_header_stdint_h=yes ac_cv_header_stdlib_h=yes ac_cv_header_string_h=yes ac_cv_header_strings_h=yes ac_cv_header_sys_stat_h=yes ac_cv_header_sys_types_h=yes ac_cv_header_unistd_h=yes ac_cv_host=i386-pc-solaris2.10 ac_cv_host_alias=i386-pc-solaris2.10 ac_cv_objext=o ac_cv_path_AS=/usr/ccs/bin/as ac_cv_path_CHMOD=/usr/bin/chmod ac_cv_path_CMP=/usr/bin/cmp ac_cv_path_CP=/usr/bin/cp ac_cv_path_DOXYGEN=no ac_cv_path_HOSTNAME=/usr/bin/hostname ac_cv_path_KILL=/usr/bin/kill ac_cv_path_LN=/usr/bin/ln ac_cv_path_LN_CP_F=/usr/bin/ln ac_cv_path_MAKEINDEX=no ac_cv_path_MV=/usr/bin/mv ac_cv_path_PDFLATEX=no ac_cv_path_PERL=/usr/bin/perl ac_cv_path_PS=/usr/bin/ps ac_cv_path_RM=/usr/bin/rm ac_cv_path_SED=/usr/bin/sed ac_cv_path_install='/opt/sfw/bin/ginstall -c' ac_cv_path_uname_prog=/usr/bin/uname ac_cv_prog_AWK=nawk ac_cv_prog_CPP='cc -E' ac_cv_prog_CXXCPP='CC -E' ac_cv_prog_TAR=gtar ac_cv_prog_YACC='bison -y' ac_cv_prog_ac_ct_AR=ar ac_cv_prog_ac_ct_CC=cc ac_cv_prog_ac_ct_F77=g77 ac_cv_prog_ac_ct_RANLIB=ranlib ac_cv_prog_ac_ct_STRIP=strip ac_cv_prog_cc_g=yes ac_cv_prog_cc_stdc= ac_cv_prog_cxx_g=yes ac_cv_prog_egrep=egrep ac_cv_prog_f77_g=yes ac_cv_prog_make_make_set=yes ac_cv_target=i386-pc-solaris2.10 ac_cv_target_alias=i386-pc-solaris2.10 am_cv_CC_dependencies_compiler_type=none am_cv_CXX_dependencies_compiler_type=none am_cv_prog_cc_stdc=no lt_cv_deplibs_check_method=pass_all lt_cv_file_magic_cmd='$MAGIC_CMD' lt_cv_file_magic_test_file= lt_cv_ld_reload_flag=-r lt_cv_objdir=.libs lt_cv_path_LD=/usr/ccs/bin/ld lt_cv_path_LDCXX= lt_cv_path_NM='/usr/ccs/bin/nm -p' lt_cv_path_SED=/usr/bin/sed lt_cv_prog_compiler_c_o=yes lt_cv_prog_compiler_c_o_CXX=yes lt_cv_prog_compiler_c_o_F77=yes lt_cv_prog_gnu_ld=no lt_cv_prog_gnu_ldcxx= lt_cv_sys_global_symbol_pipe='sed -n -e '\''s/^.*[ ]\([BDRT][BDRT]*\)[ ][ ]*\(\)\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2\3 \3/p'\''' lt_cv_sys_global_symbol_to_c_name_address='sed -n -e '\''s/^: \([^ ]*\) $/ {\"\1\", (lt_ptr) 0},/p'\'' -e '\''s/^[BCDEGRST] \([^ ]*\) \([^ ]*\)$/ {"\2", (lt_ptr) \&\2},/p'\''' lt_cv_sys_global_symbol_to_cdecl='sed -n -e '\''s/^. .* \(.*\)$/extern int \1;/p'\''' lt_cv_sys_max_cmd_len=262144 lt_lt_cv_prog_compiler_c_o='"yes"' lt_lt_cv_prog_compiler_c_o_CXX='"yes"' lt_lt_cv_prog_compiler_c_o_F77='"yes"' lt_lt_cv_sys_global_symbol_pipe='"sed -n -e '\''s/^.*[ ]\\([BDRT][BDRT]*\\)[ ][ ]*\\(\\)\\([_A-Za-z][_A-Za-z0-9]*\\)\$/\\1 \\2\\3 \\3/p'\''"' lt_lt_cv_sys_global_symbol_to_c_name_address='"sed -n -e '\''s/^: \\([^ ]*\\) \$/ {\\\"\\1\\\", (lt_ptr) 0},/p'\'' -e '\''s/^[BCDEGRST] \\([^ ]*\\) \\([^ ]*\\)\$/ {\"\\2\", (lt_ptr) \\&\\2},/p'\''"' lt_lt_cv_sys_global_symbol_to_cdecl='"sed -n -e '\''s/^. .* \\(.*\\)\$/extern int \\1;/p'\''"' mysql_cv_sys_os=SunOS ## ----------------- ## ## Output variables. ## ## ----------------- ## ACLOCAL='${SHELL} /web/source/mysql-4.1.15/missing --run aclocal-1.8' ALLOCA='' AMDEPBACKSLASH='\' AMDEP_FALSE='#' AMDEP_TRUE='' AMTAR='${SHELL} /web/source/mysql-4.1.15/missing --run tar' AR='ar' AS='/usr/ccs/bin/as' ASSEMBLER_FALSE='' ASSEMBLER_TRUE='' ASSEMBLER_sparc32_FALSE='' ASSEMBLER_sparc32_TRUE='' ASSEMBLER_sparc64_FALSE='' ASSEMBLER_sparc64_TRUE='' ASSEMBLER_x86_FALSE='' ASSEMBLER_x86_TRUE='' AUTOCONF='${SHELL} /web/source/mysql-4.1.15/missing --run autoconf' AUTOHEADER='${SHELL} /web/source/mysql-4.1.15/missing --run autoheader' AUTOMAKE='${SHELL} /web/source/mysql-4.1.15/missing --run automake-1.8' AVAILABLE_LANGUAGES='czech danish dutch english estonian french german greek hungarian italian japanese japanese-sjis korean norwegian norwegian-ny polish portuguese romanian russian serbian slovak spanish swedish ukrainian' AVAILABLE_LANGUAGES_ERRORS=' czech/errmsg.sys danish/errmsg.sys dutch/errmsg.sys english/errmsg.sys estonian/errmsg.sys french/errmsg.sys german/errmsg.sys greek/errmsg.sys hungarian/errmsg.sys italian/errmsg.sys japanese/errmsg.sys japanese-sjis/errmsg.sys korean/errmsg.sys norwegian/errmsg.sys norwegian-ny/errmsg.sys polish/errmsg.sys portuguese/errmsg.sys romanian/errmsg.sys russian/errmsg.sys serbian/errmsg.sys slovak/errmsg.sys spanish/errmsg.sys swedish/errmsg.sys ukrainian/errmsg.sys' AWK='nawk' CC='cc' CCAS='cc' CCASFLAGS=' ' CCDEPMODE='depmode=none' CC_VERSION='' CFLAGS=' ' CHECK_PID='/usr/bin/kill -0 $$PID > /dev/null 2> /dev/null' CHMOD='/usr/bin/chmod' CLIENT_EXTRA_LDFLAGS='' CLIENT_LIBS='' CMP='/usr/bin/cmp' COMPILATION_COMMENT='' COMPILE_PSTACK_FALSE='' COMPILE_PSTACK_TRUE='' CONF_COMMAND='./configure '--prefix=/web/mysql' 'CC=cc' 'CXX=CC'' CP='/usr/bin/cp' CPP='cc -E' CPPFLAGS='' CXX='CC' CXXCPP='CC -E' CXXDEPMODE='depmode=none' CXXFLAGS=' ' CXXLDFLAGS='' CXX_VERSION='' CYGPATH_W='echo' DARWIN_MWCC_FALSE='' DARWIN_MWCC_TRUE='#' DEFS='' DEPDIR='.deps' DOT_FRM_VERSION='6' DOXYGEN='no' DVIS='' ECHO='echo' ECHO_C='' ECHO_N='-n' ECHO_T='' EGREP='egrep' EXEEXT='' F77='g77' FFLAGS='-g -O2' FIND_PROC='/usr/bin/ps -p $$PID | grep -v grep | grep mysqld > /dev/null' GETCONF='' GXX='no' HAVE_NDBCLUSTER_DB_FALSE='' HAVE_NDBCLUSTER_DB_TRUE='' HAVE_NETWARE_FALSE='' HAVE_NETWARE_TRUE='' HOSTNAME='/usr/bin/hostname' INSTALL_DATA='${INSTALL} -m 644' INSTALL_PROGRAM='${INSTALL}' INSTALL_SCRIPT='${INSTALL}' INSTALL_STRIP_PROGRAM='${SHELL} $(install_sh) -c -s' KILL='/usr/bin/kill' LD='/usr/ccs/bin/ld' LDFLAGS='' LIBDL='' LIBEDIT_LOBJECTS='' LIBOBJS='' LIBS='' LIBTOOL='$(SHELL) $(top_builddir)/libtool --preserve-dup-deps' LIB_EXTRA_CCFLAGS='' LM_CFLAGS='' LN='/usr/bin/ln' LN_CP_F='/usr/bin/ln -s' LN_S='ln -s' LOCAL_FALSE='' LOCAL_TRUE='#' LTLIBOBJS='' MACHINE_TYPE='i386' MAKEINDEX='no' MAKEINFO='${SHELL} /web/source/mysql-4.1.15/missing --run makeinfo' MAKE_BINARY_DISTRIBUTION_OPTIONS='' MAKE_SHELL='' MT_INCLUDES='' MT_LD_ADD='' MV='/usr/bin/mv' MYSQLD_DEFAULT_SWITCHES='' MYSQLD_EXTRA_LDFLAGS='' MYSQLD_USER='' MYSQL_BASE_VERSION='4.1' MYSQL_NO_DASH_VERSION='4.1.15' MYSQL_SERVER_SUFFIX='' MYSQL_TCP_PORT='' MYSQL_TCP_PORT_DEFAULT='3306' MYSQL_UNIX_ADDR='' MYSQL_VERSION_ID='40115' NDB_DEFS='' NDB_SCI_INCLUDES='' NDB_SCI_LIBS='' NDB_VERSION_BUILD='15' NDB_VERSION_MAJOR='4' NDB_VERSION_MINOR='1' NDB_VERSION_STATUS='' NOINST_LDFLAGS='' NON_THREADED_LIBS='' OBJEXT='o' PACKAGE='mysql' PACKAGE_BUGREPORT='' PACKAGE_NAME='' PACKAGE_STRING='' PACKAGE_TARNAME='' PACKAGE_VERSION='' PATH_SEPARATOR=':' PDFLATEX='no' PDFMANUAL='' PERL5='/usr/bin/perl' PERL='/usr/bin/perl' PROTOCOL_VERSION='10' PS='/usr/bin/ps' RANLIB='ranlib' RM='/usr/bin/rm' SAVE_ASFLAGS='' SAVE_CFLAGS='' SAVE_CXXFLAGS='' SAVE_CXXLDFLAGS='' SAVE_LDFLAGS='' SED='/usr/bin/sed' SET_MAKE='' SHARED_LIB_VERSION='14:0:0' SHELL='/bin/bash' STATIC_NSS_FLAGS='' STRIP='strip' SYSTEM_TYPE='pc-solaris2.10' TAR='gtar' TARGET_LINUX='false' TERMCAP_LIB='' THREAD_LOBJECTS='' THREAD_LPROGRAMS='' VERSION='4.1.15' WRAPLIBS='' YACC='bison -y' ZLIB_DEPS='' ZLIB_INCLUDES='' ZLIB_LIBS='' ac_ct_AR='ar' ac_ct_CC='cc' ac_ct_CXX='' ac_ct_F77='g77' ac_ct_GETCONF='' ac_ct_RANLIB='ranlib' ac_ct_STRIP='strip' am__fastdepCC_FALSE='' am__fastdepCC_TRUE='#' am__fastdepCXX_FALSE='' am__fastdepCXX_TRUE='#' am__include='include' am__leading_dot='.' am__quote='' bdb_includes='' bdb_libs='' bdb_libs_with_path='' bench_dirs='' bindir='${exec_prefix}/bin' build='i386-pc-solaris2.10' build_alias='' build_cpu='i386' build_os='solaris2.10' build_vendor='pc' datadir='${prefix}/share' docs_dirs='' exec_prefix='NONE' fs_dirs='' host='i386-pc-solaris2.10' host_alias='' host_cpu='i386' host_os='solaris2.10' host_vendor='pc' includedir='${prefix}/include' infodir='${prefix}/info' innodb_includes='' innodb_libs='' innodb_system_libs='' install_sh='/web/source/mysql-4.1.15/install-sh' isam_libs='' libdir='${exec_prefix}/lib' libexecdir='${exec_prefix}/libexec' libmysqld_dirs='' linked_client_targets='' linked_netware_sources='' localstatedir='${prefix}/var' man_dirs='' mandir='${prefix}/man' mkdir_p='$(mkinstalldirs)' ndb_bin_am_ldflags='' ndb_cxxflags_fix='' ndb_mgmclient_libs='' ndb_opt_subdirs='' ndb_port='' ndb_port_base='' ndb_transporter_opt_objs='' ndbcluster_includes='' ndbcluster_libs='' ndbcluster_system_libs='' netware_dir='' oldincludedir='/usr/include' openssl_includes='' openssl_libs='' orbit_idl='' orbit_includes='' orbit_libs='' prefix='/web/mysql' program_transform_name='s,x,x,' pstack_dirs='' pstack_libs='' readline_basedir='' readline_dir='' readline_h_ln_cmd='' readline_link='' readline_topdir='' sbindir='${exec_prefix}/sbin' server_scripts='' sharedstatedir='${prefix}/com' sql_client_dirs='' sql_server_dirs='' sql_union_dirs='' subdirs='' sysconfdir='${prefix}/etc' target='i386-pc-solaris2.10' target_alias='' target_cpu='i386' target_os='solaris2.10' target_vendor='pc' thread_dirs='' tools_dirs='' uname_prog='/usr/bin/uname' vio_dir='' vio_libs='' zlib_dir='' ## ------------- ## ## Output files. ## ## ------------- ## AVAILABLE_LANGUAGES_ERRORS_RULES='./ac_available_languages_fragment' ## ----------- ## ## confdefs.h. ## ## ----------- ## #define DOT_FRM_VERSION 6 #define HAVE_DLFCN_H 1 #define HAVE_INTTYPES_H 1 #define HAVE_MEMORY_H 1 #define HAVE_STDINT_H 1 #define HAVE_STDLIB_H 1 #define HAVE_STRINGS_H 1 #define HAVE_STRING_H 1 #define HAVE_SYS_STAT_H 1 #define HAVE_SYS_TYPES_H 1 #define HAVE_UNISTD_H 1 #define MACHINE_TYPE "i386" #define NDB_VERSION_BUILD 15 #define NDB_VERSION_MAJOR 4 #define NDB_VERSION_MINOR 1 #define NDB_VERSION_STATUS "" #define PACKAGE "mysql" #define PACKAGE_BUGREPORT "" #define PACKAGE_NAME "" #define PACKAGE_STRING "" #define PACKAGE_TARNAME "" #define PACKAGE_VERSION "" #define PROTOCOL_VERSION 10 #define SPRINTF_RETURNS_GARBAGE 1 #define STDC_HEADERS 1 #define SYSTEM_TYPE "pc-solaris2.10" #define VERSION "4.1.15" #endif #ifdef __cplusplus extern "C" void exit (int); configure: exit 1 ... |
| 24.11.2005, 18:35:04 |
плюнул я на это, решил gcc использовать с флагами CC=gcc CXX=gcc CFLAGS="-O3" CXXFLAGS="-O3" конфигурация проходит нормально, а вот make останавливается пишет if test "$dot_seen" = "no"; then \ make "$target-am" || exit 1; \ fi; test -z "$fail" make: Fatal error: Command failed for target `install-recursive' что за беда такая? ... |
| 25.11.2005, 18:15:50 |
start [/forum/topic.php?desktop=1&fid=47&tid=1853391]: |
194ms |
47ms |
| others: | 243ms |
| total: | 518ms |
