не могу разобраться
Warning: require_once(Zend/Application.php) [function.require-once]: failed to open stream: No such file or directory in Z:\home\localhost\www\forload.kz\index.php on line 18 Fatal error: require_once() [function.require]: Failed opening required 'Zend/Application.php' (include_path=';.;/usr/local/php5/PEAR') in Z:\home\localhost\www\forload.kz\index.php on line 18 Пытаюсь разобраться в чужом проекте Что за ошибку кто мне может разобраться index.php <?php // Define path to application directory defined('APPLICATION_PATH') || define('APPLICATION_PATH', realpath(dirname(__FILE__) . '/../zend_apps/forload/application')); // Define application environment defined('APPLICATION_ENV') || define('APPLICATION_ENV', (getenv('APPLICATION_ENV') ? getenv('APPLICATION_ENV') : 'production')); // Ensure library/ is on include_path set_include_path(implode(PATH_SEPARATOR, array( realpath(APPLICATION_PATH . '/../library'), get_include_path(), ))); /** Zend_Application */ require_once 'Zend/Application.php'; // Create application, bootstrap, and run $application = new Zend_Application( APPLICATION_ENV, APPLICATION_PATH . '/configs/application.ini' ); $application->bootstrap() ->run(); ... |
| 08.06.2012, 15:21:02 |
не могу разобраться
altay omarovNo such file or directory in Failed opening required Перевести? :) ... |
| 08.06.2012, 15:54:55 |
не могу разобраться
Pavel Kurakinaltay omarovNo such file or directory in Failed opening required Перевести? :) ))) ... |
| 08.06.2012, 16:09:00 |
start [/forum/topic.php?desktop=1&fid=23&tid=1465063]: |
176ms |
52ms |
| others: | 194ms |
| total: | 465ms |
